Hello, My supervisor wants an emergency stop system installed onto the sheet metal roll in the Auto shop. The system is activated via a push button switch that is hit by the knee whever the person is standing in front of the machine. I've got the pushbutton switch figured out, the problem is that my supervisor wants the emergency switch to trigger another switch nearby(normally open) that will close and then serve as a bypass to prevent the machine from being turned on again, he also wants that switch to require a manual reset after this has occured so that an accident does not occur. The problem is that the supervisor does not want the emergency stop switch to serve as the reset switch, he wants the reset switch to be located out of reach of the individual employee, thus eliminating the possiblity of simply acquiring a push/pull E-stop switch, If anyone knows of a switch like this I would greatly appreciate any information you could give me.
Thank you.
