Previous in Forum: Emergency Stop Switch and Reset Switch   Next in Forum: ESD Compliance
Magnetic Proximity Sensor Equivalent to Hamlin 59070-010
06/06/2008 9:56 AM
Hi,
I am using this sensor for a sensing design project in a wet environment. The sensor appears to pick up moisture and malfunction. Are there any other vendors of magnetic proximity sensors out there that makes an equivalent mechanically designed sensor to this that is waterproof?
ECU Designer
Daytona Beach, FL
Engineering Fields - Instrumentation Engineering - New Member Hobbies - Fishing - New Member
Re: Magnetic Proximity Sensor Equivalent to Hamlin 59070-010
06/06/2008 11:32 AM
Try out Google with this request: "proximity sensor IP68" or "proximity sensor IP69"
I am wondering is really IP67 not enough?
06/06/2008 4:26 PM
ECUD; try www. allelectronics.com they have a CHERRY sealed unit cat#ms-39 perry
06/06/2008 4:54 PM
Thanks for all the good info. I have also found a Cherry PN MP200701 That may work for my application too.
Register to Reply 3 comments
caramba (1); ECUDesigner (1); perry (1)
