Previous in Forum: Intools   Next in Forum: Process Conroller
Gas and Liquid Ultrasonic Flowmeters
06/06/2008 11:57 AM
Which related with on-line gas or liquid flowmeter for custody transfer .Can i substitute with the prover in case of failor in service of the main meter instrument.Which is the best think 2-redundant meters with one flow computer OR the prover can work instead of the main meter (without redundant) which the best choice?In addition the meter type is ultrasonic meter skid.
Thanks
Re: Gas and Liquid Ultrasonic Flowmeters
06/09/2008 4:47 AM
Start again from the beginning please.
  • Please describe the current situation
  • What fluids are being transferred? At what temperature and pressure?
  • What is the line size?
  • What are the current difficulties?
  • What improvements are required?
Etc.
06/09/2008 9:48 AM
I have not seen a spare meter in 20 years. The cost to pipe up the prover to be a spare meter would cost more than just buying a spare meter.
Good Answers: 122
06/09/2008 11:27 AM
Greetings!
Top of the day to you!
The decision whether to install a redundant meter or not should be based upon the production and safety requirements of your system.
If production downtime, product quality, and/or safety due to equipment calibration, service, and/or repair is not an issue, then a redundant meter is not necessary.
As I do not know the dynamics or risks surrounding your process, it would be impossible to answer the question correctly but to me, the idea of using a "prover" as a substitute for a flowmeter doesn't sound like a good viable solution.
My best guess would be that if you are "batching" chemical compounds for refining or combination, a careful, in-depth analysis of your process is required to identify all of the risks and requirements before a decision is made.
The idea of having redundant metering and controls in any process is to provide "seamless", un-interrupted operation that may be critical (especially when combining or refining chemicals/compounds) to the quality of the product as well as maximizing production at a minimum cost.
I hope this helps.
Register to Reply 3 comments
PWSlack (1); SHOCKHISCAN (1); vicini (1)
