Previous in Forum: ASTM A105   Next in Forum: Metal Contamination of Water
retained austenite
06/09/2008 9:31 AM
what is the process of formation of retained austenite
Pathfinder Tags: different phases of iron
Spain - Member - New Member Engineering Fields - Nuclear Engineering - New Member
Good Answers: 25
Re: retained austenite
06/09/2008 11:03 AM
There is no "formation" of retained austenite. It's a result of quenching.
Quenching heat treatment is accomplished by heating the steel to a temperature high enough to allow the complete mass be in the austenitic form and then a quick cooling (water, oil and even air cooling). The quenching purpose use to be to transform by this fast cooling the austenite in a no-equilibrium phase, usually martensite which is much harder (and more fragile).
Cooling up to room temperature, sometimes doesn't give time enough to achieve complete transformation of austenite to martensite, and as a result, some austenite is still present even theoretically austenite isn't stable at room temperature ( in fact for plain carbon steel is stable only above 723ºC).
During quenching, there is a temperature at which austenite begins to transform to martensite. It's called Ms. And the temperature when the transformation has finished is called Mf. In many steels Mf temperature is below room temperature, so full transformation of austenite cannot occur by simple quenching.
That amount of austenite not transformed during quenching is what is called "retained austenite".
If after quenching a tempering treatment is given, some or all of the "retained austenite" transforms into more stable phases.
Sometimes, when Mf is below room temperature and full transformation (no retained austenite) is desired, there is a sort of quench called "sub-zero quenching" in which the quenching bath is at much lower than room temperatures, at least to reach Mf.
Best regards
Good Answers: 243
06/10/2008 3:10 PM
Kwetz you nailed it! GA.
We use the term cryogenic quench in place of subzero quench.
Cryogenic quench followed by a subsequent temper is to convert the"retained Austenite" into marteniste and then temper it to prevent brittleness.
milo
Register to Reply 2 comments
