We have an indoor concrete container of filtered tap water, open top, not temperature controlled, with skimmers and regular monitoring of basic water chemistry. It is desired to empty the container in the nearby Potomac River and do so within the guidance of the Maryland State and federal environmental rules. This situation is problematic for a variety of reasons.
- First, the volume of the containment is about 9.8 million gallons (33.7 million liters.)
- Secondly, it is contaminated with several metals, most notably Silver at 0.008 mg//L. (Maryland allows 0.0032 mg/L total Silver in the river.)
- Concentration of chlorine is at 0.06 mg/L.
After some investigation I have found that Potassium Iodide (KI) can be added to the water and a small amount of it will combine with any ionic Silver, precipitating out to the bottom as Silver Iodide (AgI,) where it can be scooped out with the other sludge. However, it occurs to me that with so much Chlorine in the water, all Silver is actually not ionic but rather in the form of Silver Chloride. Silver Chloride at this concentration will certainly not precipitate out of the water.
One reference noted that the Silver Chloride can be broken down to ionic Silver and Chlorine using either heat (which is impractical) or with illumination.
The vision at this point is to brightly illuminate the water as it re-enters the basin from filtration (at 1700 gpm) to break down the silver Chloride and immediately thereafter dose it with a stream of Potassium Iodide to drop the Silver to the bottom.
There are issues with this vision, including:
- First, this is an engineer's rather than a chemist's vision.
- Secondly, what should be done (if anything) with the Potassium.
- Thirdly, how bright must the illumination be, or if such a process is needed at all.
- Fourth, what is the better solution?
Thanks for your thoughts and suggestions.
Best Regards.
