Previous in Forum: Metal Contamination of Water   Next in Forum: Hydrogen Production
Pumping Problem
06/10/2008 1:03 AM
Hi to all
Small problem I am hoping you can advise on:
We have an electrochlorination package ultimately generating sodium hypochlorite solution. one of the by products of the electrolysis reaction is hydrogen gas. Even though Hydrogen has a low solubility there will be dissolved hydrogen in the hypochlorite solution - my question is what effect will this dissolved hydrogen have on the overall vapour pressure of the solution? - this is in relation to a pumping cavitation problem- I have had rumours that the resultant vapour pressure could be as high as 7 bar is this feasible?
Thanks
Matthew
Re: pumping problem
06/10/2008 5:49 AM
Any hydrogen will appear as bubbles in the stream, and at the levels introduced by an electrochlorination package there will be very little effect.
If there is a cavitation problem then it is unlikely that hydrogen bubbles are the primary cause; look elsewhere for it.
Re: Pumping Problem
06/11/2008 6:12 AM
Yes ofcourse it will affect the vapour pressure and hence lead to cavitation in pump if suction head of the pump will not be sufficient to take care of this vapor pressure orthere is no provision to escape vapor.
Moto
Re: Pumping Problem
06/11/2008 9:25 AM
"dissolved" hydrogen will do nothing in pumping. Think about pumping soda pop, no difference. The "dissolved" hydrogen will stay dissolved unless you (a) heat it up (b) lower the pressure or (c) allow another gas with a higher rate of solubility come in contact.
Re: Pumping Problem
06/11/2008 9:42 AM
Thanks Vicini
There is a series of pipe diameter reductions between the tank exit and the pump impeller - my main point was if the hydrogen were to break out of solution is it feasible that the overall vapour pressure of the hypochlorite solution could be raised to such a high figure as 7 bar?
Matthew
Re: Pumping Problem
06/11/2008 9:49 AM
If the pressure drop due to friction lwered the pressure lets say from 2atm to 1 atm, the hydrogen that comes out of solution would just flow backwards to where it came from.
Also, the hydrogen coming out of solution would cool the stream a little and some, say 10% would go back into solution.
Most pumps can handle a 5% free vapour phase of gases in a saturated solution and not cavitate. You pump manufacturer could speek to you about this.
Re: Pumping Problem
06/12/2008 9:14 AM
I do not think the hydrogen will have much effect one way or the other. At 20C its solubility in water is .0016g/kg . It is true that if you are getting cavitation you can get very short lived "bubbles" with a very high pressure and temperature and this can erode the metal parts of the pump.
Register to Reply 6 comments
Anonymous Poster (1); matlinsman (1); PWSlack (1); Tushar_moto (1); vicini (2)
