Previous in Forum: rmu   Next in Forum: Neutral to Earth Voltage
Electricity
06/10/2008 9:29 AM
I have a question that if there is a bulb of 12v and 3A (36w)
and if we give 3v and 12A to that bulb, is it work..?
Good Answers: 918
Re: Electricity
06/10/2008 9:47 AM
No. Because the resistance of the bulb is way too high to draw that much current at 3 volts.
Remember the equation I = E/R
Current = Volts / Resistance
Resistance of the bulb is the fixed component here at 4 Ω. So, the only way you can increase current is to increase voltage. Lowering the voltage will decrease the current.
Re: Electricity
06/10/2008 9:56 AM
You can't just swap quantities around willy nilly...
Do you think your car would run if you swapped the fuel/air ratio round the other way?
Or maybe you add a pinch of salt to a cup of rice when cooking...try that round the other way....
Reply Score 1 for Off Topic
Re: Electricity
06/10/2008 11:28 AM
Like a car headlight bulb?
United States - Member - New Member Engineering Fields - Electrical Engineering - New Member
Re: Electricity
06/11/2008 8:25 AM
First you wouldn't be able to give the poor little bulb 12 A unless you injected it with a hat box. Not enough load.
Don't confuse Power with the components that make it up.
“There's a sucker born every minute, and I happen to be one of them”
Re: Electricity
06/11/2008 2:46 PM
Even if you ignore Ohm's Law, the current carrying capacity of the wiring almost certainly could not support the amperage.
Anonymous Hero (1); pantaz (1); PWSlack (1); T Man (1); user-deleted-1105 (1)
