Previous in Forum: Air Conditioning   Next in Forum: Katrina's Victims Status?
10 comments
Caustic Tanks
06/11/2008 8:02 AM
Good day all
I work in a facility that deals with plenty of chemicals,
but i noticed some thing odd regarding the caustic storage tank as it was the only tank that doesn't have eye sight glass attached to it...
I keep asking why but no answer..
is any one have any idea if we need to attach eye sight glass to a caustic tank
what the best way to do that....
thank you
An Engineer Creats the World that which never was. Theodore Van Karme
Re: CAUSTIC TANKS
06/11/2008 8:10 AM
Strong caustic liquors are generally opaque, and as the level drops, the inside of the hypothetical sight glass will become coated with dried caustic soda crystals. Looking through the glass will not be possible in these circumstances.
It's not fitted, because it would be as 'useful as a chocolate teapot'.
Re: CAUSTIC TANKS
06/11/2008 11:10 PM
Depending on the material the tank is made out of, a light may be used at the top of the tank allowing the material level to be seem through the tank. In my industry that is what is used for caustic and acid storage.
Re: CAUSTIC TANKS
06/12/2008 12:25 AM
Generally the sight glass becomes opaque with caustic soda water and hence level not visible.
so it is not used
Best Regards, Shivaram
Re: CAUSTIC TANKS
06/12/2008 7:28 AM
what about it is phosphoric acid or hypo?
Location: Next to the Prime Merridian (51°29'34.50"N 0°13'32.85"W)
Re: CAUSTIC TANKS
06/12/2008 5:49 AM
I still believe a chocolate teapot can be useful if they realise what's it made of prior to using it as a pot more so than the visual sight-glass on the tank.
Making mistake is part of learning.
Re: Caustic Tanks
06/12/2008 4:31 AM
why do you need asight glass? you need to know the level in the tank so you can install alevel indicator you can have alow level which can start feeding and hight level to stop the feeding
Good Answers: 18
Re: Caustic Tanks
06/12/2008 8:13 PM
Using an external level indicator (mechanical, or a weight indicator or other on the tank ) would likely be easiest.
Re: Caustic Tanks
06/12/2008 4:50 PM
Not only will the sodium hydroxide precipitate out on the glass, but it would tend to etch also, making hard to see through and eventually weakening the glass.
Re: Caustic Tanks
06/13/2008 7:22 AM
is it same case in phosphoric acid solution tank?
Re: Caustic Tanks
06/13/2008 7:55 AM
Dear Sir,
I really appreciate your pin pointed question.
The storage place where the hazardous chemicals are kept, should invariably be visited with adequate protective gear.
Caustic tanks with caustic lye inside is a very very dangerous and hazardous chemical.
One should not take any chances , but safely put on a protective gear for the human eye. As it costs nothing as compared to the price of loosing ones eye sight.
In fact why we should play with the hazardous chemical and why we should visit such dangerous site without wearing the requisite protective gear?
First we should ask our conscious as to whether I am endangering the limb to any risk, and then proceed to visit the hazardous chemical site.
Regards,
Ulhas Pradhan
Register to Reply 10 comments
agua_doc (1); Anonymous Poster (2); billybolbol (2); hikmat el quineh (1); Isti80 (1); PWSlack (1); shivaganti (1); umpradhan (1)
