I have 30M of LDF 450 signal cable with 7 M of it grouted in a Cable bolt Hole. This cable was supposed to monitor ground movement but it was not protected properly and was destroyed during a blast by fly rock. A small section survives sticking out the hole. The cable cannot be read casually as it is just above a 100m hole. Cutting out the damaged section and rejoining it with the standard connectors (L4PNM RC - RingFlare Connectors) is not an option as the signal degrades once the cable is broken and reconnected. Is there another way to reconnect without data corruption over such a distance?
