Previous in Forum: LDF 450 Signal Corruption   Next in Forum: Electronic Data Transmission from Medical Devices
My electric circuit has the IC L6561 broken down
08/23/2006 8:15 AM
My electric circuit has the IC L6561 broken down. How can I find the compatible IC? Because I can't buy the IC L6561. I want to check if there is another IC compatible with IC L6561. How can I do?
maufi
try DigiKey
08/23/2006 11:49 PM
http://www.digikey.com/scripts/DkSearch/dksus.dll? Criteria?Ref=9468&Site=US&Cat=34276374 Or just go to http://www.digikey.com type in L6561 and hit search. Then select the second entry under IC's and take your pick. Good Luck!
Popular Science - Weaponology - New Member Hobbies - Musician - New Member
Re:try DigiKey
08/24/2006 7:18 AM
Also, NewarkInOne has 300+ if these chips at $4.50 ea.
Register to Reply 2 comments
You might be interested in: Circuit Breakers, IC Modems, IC Timers
