Previous in Forum: Concrete: 3500psi vs 5000psi   Next in Forum: Non-Tendered Items
Annular Plate of Atmospheric Tank
06/12/2008 3:46 AM
I have a tank of 500,000 bbls having an annular plate with a flexible rubber / seal in between the annular palte and the foundation. Can someone explain why a gap is provided between the annular plate and the foundation and what is teh function of the seal.
rgds
Mogambo
Re: Annular plate of atmospheric tank
06/12/2008 3:57 AM
To even out weight distribution?
Hobbies - DIY Welding - pipewelder
Re: Annular Plate of Atmospheric Tank
06/13/2008 11:15 AM
It could be there for expansion and to seal the bottom of the tank from moisture and corrosion from outside water seeping in under the tank. We have had a problem with this on allot of our tanks when the grout cracks under the annular ring and moisture gets in under the tank. I have used a rubber type material to replace the grout in the past and it works very well. I forget the name of the company that makes the product we use but is not real expensive and very easy to install when compared to re-grouting around a tank.
pipewelder
pipewelder
