Previous in Forum: Electrical Demand Load for an Apartment Building   Next in Forum: Cable Trays
Drives
06/12/2008 8:50 AM
We have used ACS 550 ABB make drive. For the 75 kW and 160 KW Motors we provided soft starter panel as well as Drives. can any body please explain why both have been used.
N.Suresh
Good Answers: 804
Re: Drives
06/12/2008 2:30 PM
Can't say for sure without seeing your system.
But sometimes, a soft starter is supplied as an emergency bypass for the motor in case the VFD is out of commission, such as for maintenance or service after a fault. They will specify a soft starter because the power grid and/or mechanical drive train cannot take the strain of starting across-the-line (DOL).
Re: Drives
06/12/2008 8:58 PM
That's definitely an odd configuration. I have used inverter drives in the past AS a soft start, but I've never seen them used in conjunction. You might want to ask the manufacturer that designed it why they are using a soft start with an inverter.
Perfection is achieved, not when there is nothing left to add, but when there is nothing else to take away
Re: Drives
06/12/2008 11:20 PM
I agree with JRaef - there are so many possibilities, without knowing the system we can't start to postulate why there are both.
Are both the VFD and the Soft Starter driving the same motor? If so, what switching mechanism is holding them in parallel? You may find that one motor only has to run at a fixed speed (so they use a soft starter), the other has to vary it's speed to suit the process. The soft starter is cheaper than a VFD, and (especially with a DOL bypass) will generate less heat when running at full power, and less noise. Less heat = more efficient = less running cost.
Critcho (1); JRaef (1); Shawn_V_Elect (1)
You might be interested in: DC Motor Drives, AC Motor Drives, Hard Drives
