Previous in Forum: Rollers / Guides for Replaceing Forging Dies on a Press   Next in Forum: How to Start a Textile Manufacturing Company
10 comments
VMM vs. CMM
06/12/2008 9:59 AM
I have taken a position with a manufacturing company of metrology grade components. We have tolerance requirements of +or- .0001 routinely and surface finish expectations that are difficult to maintain when inspecting using contact methods, i.e. micrometers, pin gages, dial indicators etc.
We are looking into purchasing a new CMM, however I wonder if a video measuring machine might be more applicable.
Our products are very small and very soft material (Alum. brass and copper).
Any suggestions as to whether VMM or CMM would have an advantage one over the other?
Re: VMM vs. CMM
06/13/2008 1:04 AM
You need both type of machines.
Video measuring system for small,flat specimens and CMM for prismatic parts of complex geometry.
There are many suppliers of video measuring systems. You will have to select machine based on parts to be inspected. These type of machine are widely used for the inspection of electronics components and plastic parts.
CMM from Zeiss is more reliable and popular, value for your money.
You can rely on their results.
Good luck.
Regards
Good Answers: 109
Re: VMM vs. CMM
06/13/2008 4:49 AM
Dear mooremarvin,
we need some more information about the parts you measure and if you measure flatness or roundness or diameter or whatelse, how many parts per second and if it is allowed to touch the parts (leaving a fine scratch on a good surface).
There are many more possibilities than you mentioned.
RHABE
Re: VMM vs. CMM
06/13/2008 9:58 AM
Here's a sample of some of the parts we make.
Re: VMM vs. CMM
06/13/2008 10:55 AM
How about a multi-sensor VMM? It has both touch probe, (CMM) and Video, (VMM) capability. You can also have them fitted with a laser scanner, but they're not as accurate as the other sensors. (Best suited for rough profile and surface inspection.)
http://www.ogpnet.com/ogpVidQuest300.jsp?page=594
Have you investigated CMM's for your application? With your stated tolerances, I'm guessing that you will need an very accurate machine. $$$$$$ That is, if you can find one that can Repeat and Reproduce inspection results. (GR&R required.)
Sucess is going from failure to failure without loss of enthusiasm... Winston Churchill
Good Answers: 243
Re: VMM vs. CMM
06/14/2008 10:08 PM
Good Answer nomination from milo. DO not purchase anything without having vendor performing a GAGE R&R Repeatability and Reproducibility study.
THIS IS CRITICAL!
milo
Good Answers: 109
Re: VMM vs. CMM
06/13/2008 5:59 PM
Hi,
these parts look like pretty many produced per day.
If you have to measure 100% then neither CMM nor VMM will do as both are not really fast.
The solution to measure many parts of the same shape is a fixture with a multitude of contacting and/or non-contacting sensors with automatic loading and unloading and alarm if something is wrong.
If you have a few parts per day only and have a lot of different parts than a CMM and or a VMM will be a good choice. Very likely measurement cost will be very high so a comparison with specialised measurement fixtures shall be done for any part.
CMM and VMM are expensive in many aspects: to buy, to operate, to have ever new touch-probes, maintenance of hard- and software, operators and their training. And the room with stabilised temperature and humidity.
Simpler solutions are likely to be better and cheaper and only the measurement fixtures (or one part per day or week) to be remeasured by a CMM.
This Will be more complicated if tolerances of 1 µm and below are required.
Get you informed about the possibilities of simple or sophisticated probes: mechanical touch probes, LVDT touch probes, Laser-triangulation, Laser confocal scanning, Laser projection, wavelength dispersion distance sensing, air-flow distance sensing, inductive sensors, eddy current sensors, capacitive sensors ....
Or get an expert to let you know.
Then decide. Or decide today but lease the expensive equipment to learn with different approaches.
RHABE
Re: VMM vs. CMM
06/13/2008 7:37 PM
Thank you very much!
You have me thinking in a different way, and I like what I am reading. Do you have any suggestions as where to direct my inquiry?
MM
Re: VMM vs. CMM
06/14/2008 2:56 AM
We may have suggestion. Please contact with us. Henryzhang1@hotmail.com
Re: VMM vs. CMM
06/14/2008 6:40 PM
Do your homework - as with any capital purchase you will have to live with your decision for many years.
If you don't already have any hardware and particularly software that you need to standardize with, then you have more flexibility in your decision.
You've received good advice to look at multi-sensor machines from OPG as well as Zeiss equipment although you will find that they are quiet expensive and may be more than you need for your application if the parts in the photo represent you typical parts.
Fixed electronic gages with SPC capabilities may be more cost effective (reliable and fast) if your do long run production although you'll need CMM data on master samples to use as "set masters". A dimensional inspection house can supply that but it will get expensive if you do it often.
Touch probing is currently more accurate than laser scanning or white light technology and also note that some CMM equipment probes "touch" harder than others which could be a surface finish issue.
also visit these sites for general info
www.hexagonmetrology.net
www.xspectsolutions.com
United States - Member - US Navy Veteran
Location: Nothing sucks more than that moment during an argument when you realize you're wrong.
Good Answers: 22
Re: VMM vs. CMM
06/14/2008 6:44 PM
You never know when it will strike, but there comes a moment when you know that you just aren't going to do anything productive for the rest of the day.
Register to Reply 10 comments
Anonymous Poster (3); markar (1); Milo (1); mooremarvin (2); Q (1); RHABE (2)
