Previous in Forum: M TECH PARTTIME OR DISTANCE MODE   Next in Forum: Long Distance, Hard Wired Communications
Designing HART feature into our 4-20 Xmitter
06/12/2008 5:48 PM
We are exploring best way to add HART capability to our existing gas monitor (GM) offered in both low power 2-wire 4-20 (sink) and a high power 3-wire 4-20 (source) models. The sink chip is XTR115 and for source we build a V/I.
Question 1: Can anyone recommend circuits / app notes that include the 20C15 (or similar) HART processor and the sink / source 4-20 circuits?
Questions 2: We are small company and don't want to join the HART foundation until we see if the option is successful. HART functionality will be limited to a few simple diagnostics, placing the GM in calibration mode, changing alarm level registers. Are there "generic" mfg. ID and device codes available we can use?
Thanks!
Pathfinder Tags: 4-20 HART
Re: Designing HART feature into our 4-20 Xmitter
06/13/2008 11:03 PM
If you're going to do this, you should either private label a HART-certified transmitter or join the HCF. HCF dues, if I remember correctly, are graduated based on company size...so you'd pay a lot less as a small company than your larger competitors do. If you want to go directly to WirelessHART, Airsprite Technologies and Pepperl+Fuchs are making OEM kits...
Walt Boyes
Editor, Control Magazine
www.controlglobal.com
mailto:wboyes@putman.net
Good Answers: 39
06/15/2008 2:51 PM
a QUESTION ON APPLICATION.
How would a wireless system perform within a steel structure such as a ship's hull. Would the steel completely absorb all RF signals or would line of sight transmission still be possible. The assumption being that deck to deck communications are not possible. How about within same deck level? In which case some sort of hard wired link from deck to deck might be feasible.
Elnav
06/16/2008 11:08 AM
Thanks. We looked at a module from Fint but its cost prohibitive and difficult to tie into our 4-20's. I'll check the Airsprite and P+F offerings you mention. So, there's no other way to offer a HART compatible device (where we buy the SMAR or ASI chips and do our own design) w/o joining HCF? I guess this explain why relatively few companies offer HART.
Good Answers: 39
06/16/2008 1:19 PM
While looking up Hart I found out Omega instrument company uses that system extensively. Would one of their 4-20 modules work in your application or ar you a manufacturer of modules and want to roll your own?
Elnav
Register to Reply 4 comments
Anonymous Poster (1); BeachRider (1); elnav (2)
