I have to run comms between a plc and a pc/hmi that are 300 metres apart. Power supply available at both ends and instrument 'clean' cable tray run available.
Was looking at ethernet but this requires booster stations every 50 metres which I want to avoid. Current thinking is an ethrnet spider hub at either end with fibre-optic over the 300 meter run.
Any other options? Would prefer copper wire solution to fibre optic.
