Previous in Forum: N type Thermocouples   Next in Forum: Inverters
India - Member - New Member
Analyzing Cable Costs
06/13/2008 1:04 AM
actully we are doing project on "cable cost analysis of 11kv and 6.6kv".i am going to compare the 4000kw raw mill (same capacity for 11kv 6.6 kv).but the size of the cable is different like 1x120+16mm^2 2XSEY(6.6KV) and 3x150+25mm^2 2XSEY(11KV).Obiviously size of the cable should differ because of two different current rating.my question is whether can i take two different cable for my calculation or not
Knowledge Sharing
Re: cable cost analysis
06/13/2008 2:25 AM
Hi,
Please follow the steps:
  • First decide the voltage .
  • Then decide about the load. (4000 kW)
  • Consider the Short Circuit Rating
  • Decide about the type of cable laying
  • Finalise the cross section based on the above factors.
It is quite obivious that the cross section of 11 kV will be higher and therby cost for cable, support structure will be more.
N.Suresh
N.Suresh
06/13/2008 2:40 AM
Hi,
N.Suresh
doubt:
actually the cross section of the cable depends upon the current rating.so higher voltage means it takes lesser current .Then why you said that cross section of 11 kV will be higher .current higher -cross section high-cost is high.(this is my opinion)
my question is can i take two different cable size for comparision
Knowledge Sharing
06/13/2008 9:32 AM
Hi ,
What i understand from Mr. Nagarajan answer is , cross section of 11 KV cable is always higher than 6.6 KV cable considering cable size is same .i.e a 300 sqmm ,11KV cable have higher cross section than 300 sqmm , 6.6KV .As higher rated voltage cable require more insulation material (XLPE .. etc) so more cross section area.
06/13/2008 7:17 AM
Hi,
Well, there are some items I assumed, but the calculation is not so difficult.
Example 1:
4000kW; approx. 430A; 6.6kV; Ik= 31.5kA; cable length= 100m; CB switch off time=0.15s;
IEC/VDE regulation; ambient temperature = 45°C; cable laid on cable tray; XLPE cable multi.
Cable according to short circuit:
According to data above, the cross section of each cable must be (worst case) mind. 85mm2 resp. 95mm2 (cable type)
Cable according to load:
Reduction factor:
Laying on tray: 0.91
Temperature: 0.87
Total= 0.91x0.87=0.7917
430A/ 0.7917 = 543A è for this value you have to find a cable which is bigger than 95mm2 (short circuit)
Cable load according IEC= 3x95è 304A
Max. cable load: 2x304A = 608A
Check: 543<608
You should use two cable 3x95/16 parallel for this Motor.
Example 2:
4000kW; approx. 250A; 11kV; Ik= 31.5kA; cable length= 100m; CB switch off time=0.15s;
According to data above, the cross section of each cable must be mind. 85mm2 resp. 95mm2
Reduction factor:
Temperature: 0.87
250A/ 0.7917 = 316A è for this value you have to find a cable which is bigger than 95mm2 (short circuit)
Check: 250<304
You should use one cable 3x95/16 for this Motor.
Last comment:
You can optimize the cable cross section if you change laying factor, temperature, etc.
Hope that the calculation is helpful.
BR
Wormnhaque
Re: Analyzing Cable Costs
06/14/2008 7:20 AM
download from dutch side
vision
http://www.phasetophase.nl/en_index.html
configure all your cases voltage and load patterns in the demo mode
calculate loadflow an go to results (it wil do for max 20 nodes)
but your case will fit
ganeshakce-electrical (1); jbz (1); Nagarajan.Suresh (1); pavan5ee (1); Wormnhaque (1)
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
