Previous in Forum: Analyzing Cable Costs   Next in Forum: Unbalancing of 3-Phases
9 comments
Inverters
06/13/2008 1:17 AM
hi all
i can understand that you can get ac supply''sine wave'' output from inverter by changing the duty cycle of the pulses to get low volts then higher then reach the peak of the input value then lower again to zero, but i do not understand how you can change the output frequency? for example from 5hz to 10hz output, does that happen when you change the pulse frequency''higher'' or change the duty cycle?
please advice
many thanks
Re: Inverters
06/13/2008 9:12 AM
You have two parameters that you can control - frequency and duty cycle.
Let's suppose that you want 100 pulses per cycle of AC. You vary the duty cycle of the pulses from 0% to 100% and back to 0% during the 100 pulses to create one cycle of your sine wave. For 5Hz, your pulse frequency would be 500 Hz. For 10Hz, your pulse frequency would be 1000Hz.
So, don't think pulse width, think frequency and duty cycle.
Re: Inverters
06/13/2008 1:28 PM
sorry sir
i am getting confused, please correct me if i am wrong? when i need 10hz output frequency i should make pulse frequency higher than when i need 5hz? how about duty cycle? should it vary the same way on 5hz and 10hz or it should be different?
thanks
Re: Inverters
06/13/2008 2:53 PM
Assuming you have the same number of pulses per cycle of AC, then yes, you need to increase the frequency of your pulses proportional to the frequency of your AC.
If I want to create a 5 Hz sine wave, using PWM, I need to first determine how many pulses I'm going to use to approximate the sine wave. Let's say I want to use 10 pulses to create each cycle of AC. The period of a 5Hz sine wave is 200mS. So the frequency of my pulses needs to be 20mS. For a 10hz sine wave, with the same number of pulses per cycle, the frequency of the pulses needs to be 10ms.
Good Answers: 247
Re: Inverters
06/14/2008 12:11 AM
I think this could use a little edit:
The period of a 5Hz sine wave is 200mS. So the period of my pulses needs to be 20mS (giving a frequency of 50Hz). For a 10hz sine wave, with the same number of pulses per cycle, the period of the pulses needs to be 10ms (giving a frequency of 100HZ).
Re: Inverters
06/14/2008 10:33 AM
sorry sir
can u explain to me about this because it is new for me?
thanks
Good Answers: 247
Re: Inverters
06/15/2008 4:22 PM
What Bhankii said was basically correct -- the period/frequency distinction was just a typo, I think -- which I corrected only because it could be confusing to someone new to the subject. Period is the time for one cycle (so the period in 60 Hz power is one second/60, or 16 milliseconds). Frequency is the number of cycles per second (1Hz = 1 cycle per second).
Good Answers: 40
Re: Inverters
06/13/2008 10:31 AM
a picture is worth a thousand words
If you filter and average these two signals, what do you get?
Re: Inverters
06/13/2008 10:49 AM
nothing - assuming these are continuous and periodic, they both average to zero. A low pass filter is what you want.
Good Answers: 40
Re: Inverters
06/13/2008 11:23 AM
right. AC signals average zero, scratch average
but you do get the get different frequencies.
Anonymous Poster (2); bhankiii (3); Blink (2); techno (2)
