Previous in Forum: yield of steel   Next in Forum: Battery Storage
14 comments
Plastic Antenna Molding
06/16/2008 7:59 AM
I need some HELP. I have an antenna that was made about 15 yrs ago and the man who made it is now deceased. I have his mold, and I know he mixed some type of polymers to make it (no fibers or cloth in it). Where can I go to find out what he mixed or to duplicate his method. It is for a unique part for work so I can not go to the store to replace it. It's appearance is black and it is a very hard type of finish. I also know that it was a liquid state that hardened to this finish. He poured it into the mold with wire and fittings in it. Can anyone give me any direction as to where to look for some resolution. I need to replace it and have a back up soon.
Re: Plastic Antenna Molding
06/16/2008 11:37 PM
Sounds like it was an epoxy mix of some sorts.
Check your local epoxy/adhesive suppliers like Dupont, Araldite, Loktite or similar.
Make sure they understand it's for an antenna, will have exposed metal parts in it, will be exposed to weather, must NOT conduct electricity and so on.
I suspect that the black colour was the available method of UV protection for the material from that era.
06/17/2008 7:34 AM
thanks
Good Answers: 46
06/17/2008 2:47 AM
can2new hello, You could try the company called
Master Bond
they have potting and encapsulation compounds and just about any other
epoxies for about any job.
btw is this antenna ham related? Because your description sounds like something I remember hearing about some time back. The antennas this person built were very good and reliable but I don't remember the name or brand.
Anyhow I hope the link helps there people should be able to help you find what you need.
An no I don't have any connections with the company other than using a couple of
there epoxies in a past job.
Charles
Metal is the material, The forge is life, The anvil and hammer bring character and soul.
06/17/2008 6:37 AM
Hi
plastics can be conductive by covering wit palladium chloride, and then you may apply electroless copper plating.
Bino
06/17/2008 7:38 AM
thanks
06/17/2008 7:37 AM
Thanks, I will look into the product.
It could have come from that original application, but it is not for that. It is for a geotechnical application.
Thanks
Good Answers: 19
06/17/2008 6:30 AM
What happened to the original antenna? Can the pieces be put back together? What sort of radio is it for? Is this antenna flexible or rigid? Does it need to be weatherproof? Is the entire antenna assembly enclosed? Must it be a particular color? Do you know if the inner conductor is single? Multiple? Straight? U-shaped? J-shaped? Coiled? Is it connected with a resistor? With a loading coil?
Unless you are trying to conceal the fact that the original antenna was lost or broken, connecting a piece of wire to a connector that will fit the socket on the radio and trimming it shorter will give you some idea of how long the wire should be. If you know what frequency or band of frequencies this device employs, you can consult tables or use formulas to determine how long to make the wire before you begin trimming. It may take several tries, but the materials won't be very costly. This wire can also serve as a temporary antenna while you create a more exact replacement.
For higher frequencies, the diameter of the antenna element and the presence (or absence) of insulated cladding over this element may also need to be considered. The dielectric constant of this insulation will make a difference as well. Good luck.
06/17/2008 7:33 AM
I still have the original. It is for a geotechnical application. Yes it is rigid. It would be great if it was waterproof, currently it is not water friendly. Yes the assembly is enclosed. (The only exposure is the fitting that connects the internal wire to the connector that is exposed ) Color is not a big deal. I believe the answer is conductor is single. The shape is circular - coiled.
I need a back up in the event this one ever breaks. I have been in the field with it and it got wet and it shut down. It is a prototype of antenna. As far as the wire and how many wraps to make I have that information. I just do not have the make and type of mis for the plastic shell for the antenna. Always wanting to improve the process, like making it waterproof etc.
All great questions. Thanks for your help.
06/17/2008 8:06 AM
You probably want to use a 2 part urethane used for casting. In order to do this properly, form without air bubbles, the entire mold, with the casting material should be vacuum degassed. This is not necessary but well advised to do.
You can buy material from:
http://www.smooth-on.com/liqplas.htm
http://www.lumicast.com/links.html
One of the industry experts in this process is Paramount and they may be willing to cast this for you (for a price) in your mold.
http://www.paramountind.com/urethane-castings.html
"Imagination is more important than knowledge. Where knowledge is limited, imagination encompasses the Universe"
06/17/2008 8:14 AM
Thanks for all these sites and info! I will look into these options
06/18/2008 7:29 AM
Flexible "rubber duck" antennae can be re-waterproofed using domestic roof repair mastic compound!
07/08/2008 10:54 AM
could be Texin 950U ?
07/08/2008 11:05 AM
thanks I will look into this
07/08/2008 11:05 AM
thanks
Register to Reply 14 comments
Anonymous Poster (4); bubbapebi (1); can2new (5); Just an Engineer (1); metalSmiths (1); plaasteek (1); PWSlack (1)
