hi.here are my qeustions regarding air compressor and compressed air system.thanks in advance =)
1)if my compressor is a 75hp rotary screw compressor with max working pressure at 8bar (cut-in pressure=5.5bar,cut-off pressure=6.0bar),what would be the actual cfm of compressed air delivered?does the setting on the cut-in and cut-off pressure ok?
2)one of the compressor room in my company have 1 unit of 75hp compressor and 1 unit of 100hp compressor.the 75hp compressor is to provide dry and oiless air while the 100hp compressor is to deliver normal dry air.is it true to say that oiless is same as contaminant-free?
>>yesterday i mounted an energy analyzer on the compressor which can record the power consumption of the compressor.from the graph that is produced after about an hour of observation,it seems that the 75hp compressor keeps loading for the whole time while the other compressor (100hp) loads and unloads at nearly same interval.can anybody give some comment on this?
3)in order to know the compressed air consumption,we need to add all the required cfm from the point of use equipments.beside this,we can also out a flowmeter at the discharge point to measure the total consumption at a certain time.is there any other way to know the air consumption because i cannot lay my hand on any flowmeter here T_T
4)pressure profile is necessary to evaluate the pressure drop in the compressed air delivery.i only managa to borrow a pitot tube from my faculty for this purpose.can it be done efficiently?can anybody suggest where is the most suitable and critical sampling point to make the measurement?
**i'll appreciate if somebody can share with me their experience doing all of this.maybe by giving me some rule of thumb to follow..thanks =)
