Previous in Forum: DCIP dye   Next in Forum: old PH test strips
removing sodium ions from a sodium salt solution
06/18/2008 9:59 AM
We are trying to get rid of sodium anions from a relatively concentrated sodium salt solution while retaining the anion .
replacing the sodium ions with other alkali metals is not an option.
For the volumes we are looking at, ion exchange is not feasible.
Is anyone aware of a chemical method that can accomplish this?
Re: removing sodium ions from a sodium salt solution
06/18/2008 11:43 PM
just want to clarify what you are asking. Basicaly you have a salt solution from which you want to remove the sodium only. Obviously that would leave either a different salt solution or an unstable and heavily ionized cloride solution. substition of the metal is not an available option. Is nonmetalic substitution possible? and have you tried using mechanical means such as electrostatic or magnetic fields to drag the sodium to one location - out of the process area?
Good Answers: 101
06/19/2008 12:24 AM
You can't chemically precipitate out sodium due to its high solubility in water. You didn't state what your salt concentration is. If it's 10,000ppm & below, you can try using electrodialysis. This process will separate the cations and anions from the water. Since you want to retain the cations, you can recombine them back into the purified water stream at the outlet.
An added advantage of using this process is that you will also recover valuable NaOH as a byproduct, thus reducing your operational costs.
United States - Member - American by birth,southern by the grace of GOD Popular Science - Weaponology - you can't carry that! Technical Fields - Technical Writing - why can't I use a pencil? Hobbies - Target Shooting - New Member
06/19/2008 8:58 AM
Try a EDI system. (electronic de ionization). You will have very heavy solution left over and there will be a chance for hydrogen gas to form so you will need a scrubber to reclaim the gas loss or to vent it.
The more complex the mind, the greater the need for the simplicity of play... If you think you can or think you can't you'll always be right
06/19/2008 10:29 AM
Ammonium carbonate, or sulfide????
Register to Reply 4 comments
Anonymous Poster (2); DVader1000 (1); logix101 (1)
You might be interested in: Softeners, Ion Exchange Resins, Flame Photometers
