Previous in Forum: AVR for three winding transformer   Next in Forum: Component query
13 comments
water level detecter
06/18/2008 12:05 PM
i am building a project to dectect the level of water in a tank using a microcontroller basically all i want to do is to put a switch in the tank that will close when the water level reaches that level so that the micro can pick that up and switch a relay off. i have finished with the program for the controller and everything works fine but my problem is the switch that i will place in the tank.Is there a switch i can use other than a probe? please help
Re: water level detecter
06/18/2008 12:17 PM
Floats..
Good Answers: 266
06/18/2008 12:48 PM
Bulb float switch for a sump pump.
06/18/2008 3:37 PM
There are loads of float switches out there. RS Farnell, Digikey will all have 'em.
Good Answers: 204
06/18/2008 10:45 PM
for jetted bath control systems, we used to use a capacitive sensor that was designed and built by us.. basically it was a fully plated circuit board in a plastic box, placed on the outside wall of the fiberglass tub, and the other half of the 'capacitor' was connected to the drain. When the water was high enough to switch the state in the tuned capacitor circuit, the circuit had then 'detected' the water level at that level where the 'sensor' was positioned.
06/18/2008 10:54 PM
Is this for fun and home or is it for real? Are you putting people or capital in danger? The suggestions above are just fine - float switches are about as cheap and standard as you can get, and they work. The cap sensor is a great way to go AND you dont have floats and things getting fouled. There are other more sophisticated sensors out there, but your syntax implies a desire for drop-dead cheap, so being careful should also be on your list....
dj
Hobbies - HAM Radio - New Member United States - Member - New Member Hobbies - Hunting - New Member
Re: water level detector
06/18/2008 11:10 PM
Program? Using a pico relay or other processor and is this just an exercise in writing code? Or--Are you hard wiring and needing to maintain liquid levels?
Those who believe in telekinetics, raise my hand --Kurt Vonnegut Jr.
06/18/2008 11:46 PM
Hi there.
I am rohinton from India. We do get float switches to control water level. Available in 12, 24 V DC & 220V ac. Floats are available in nylon, Pu foam, stainless steel etc. We use for our controlling water level in our own design PRE COOLER for air conditioner. Called Genie The Power Saver. we buy switches from Shridhan international in India. You may check the site www.shridham.com.
If you need more help contact me
Regards
Rohinton Panthaki
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
Re: water level undefined
06/19/2008 12:53 AM
Hello gdallas2,
you did not say if you also wanted to control the water level. I note you mention a microcontroller. The Royal Society for the Blind make a very cheap and simple device for telling you when the water has reached a certain level in a bath. Is is battery powered with a buzzer. Very cheap, and you could just hang it on a length of string, (if you want really cheap!).
jfmfit
Good Answers: 15
06/19/2008 3:38 AM
Didn't we have this question a few weeks ago?
Qn, Whats the differance between a Snake and a Onion? Ans, No one cries when you chop up a Snake
06/19/2008 9:08 AM
As others have said, float switrches are the cheapest probably. However, if you want to eliminate the electrical current being in the water, you can use a pressure switch such as manufactured by Mercoid and others. Some of these are relatively expensive, while a simple low-pressure switch can be as cheap as a float switch. It would require a tube be placed in the water and the setting adjusted. When the level gets to the level you have set, the pressure switch would close. These closing contacts would be located somewhere other than in the water.
All that is necessary for the triumph of evil is for good men to do nothing. - Edmund Burke
06/19/2008 11:43 AM
You could use an optical transiver system to level control.
06/21/2008 4:23 PM
hi gdallas2, in every household washingmachine there is a switch to control the waterlevel. Its basically a 6 mm (1/4") rubber hose connected to the bottom of the tank and the switch, which is placed at the desired level outside the tank. When the water reaches the max level, the airpressure inside the rubbertube pushes a membrane which is connected to the switch, and you have your level switch without electricity in the water, and, may I add, very affordable, if you can get your hands on a machine to be dumped.
I plan to use a couple of these switches to control waterlevel in a drain-back solar water heating system, because the open expansiontank will be placed just under the panels inside the attick, and not easily accessable. If level is not right, both running and still, I will get a warning light.
Good luck with your project
moe
Don't think, play!
07/27/2008 10:56 AM
IFM Effector makes some really good 24vdc programable level detectors.
Register to Reply 13 comments
Anonymous Poster (3); chrisg288 (1); doug johnson (1); jfmfit (1); Kilgore Trout (1); moe (1); ozzb (1); RCE (1); Snaketails (1); The Commoner (1); user-deleted-1105 (1)
