Previous in Forum: It Will Be Run Over Thousands of Times   Next in Forum: SRAM EDAC scheme - help save an astronaut
Industrial Engineer- Aerospace
06/18/2008 12:33 PM
I'm looking for assistance in perfecting a process that uses Easy Flow 45 silver solder. A heater mat with advance alloy, 294 ohms/circular mil/ft. Does anyone have equipment other than resistence welders for this material. We currently use a resistence welder w/a carbon block that heats to 1350 degrees F. It seems crude. and the excessive heats makes the wires harden and break.
Location: Globaly - very close to the southern most point of Canada
Good Answers: 12
Re: Industrial Engineer- Aerospace
06/19/2008 8:30 AM
I'm not quite sure about your application, but we use induction to heat and braze silver solder for aerospace tube applications.
-why bother doing it wrong when it will be anyway.......
Good Answers: 109
06/19/2008 3:03 PM
Hi,
please specify what is : Easy Flow 45 and which material do you want to braze?
It is very likely that some other mechanism is responsible for brittleness.
RHABE
Good Answers: 12
06/20/2008 10:21 AM
If excessive heat is causing issues then you may want to consider using a temperature sensitive material such as Tempilaq. It changes colour at different temperatures to indicate a heat limit has been reached.
This may help you tune in your process.
See link:
http://www.tempil.com/product.asp
07/07/2008 6:08 AM
This application appears to be a possible candidate for induction heating. The carbon block can be heated using this process in a controllable manner which can therefore prevent overheating. Without further information as regards size etc. it would be difficult to suggest a suitable machine capacity.
gdevine (2); RHABE (1); uffarndan (1)
You might be interested in: Military (MIL-SPEC) Connectors, Plastic Welders
