Previous in Forum: Electrical breaking of hydro-generator of 96 MW.   Next in Forum: heat element sizing or BTU cal
single phase motor
06/19/2008 9:40 AM
hi every body
i understand that the three phase motor turn because the rotor is following the magnetic flux of phase A,B,then C and so on.
but i do not understand about single phase motor, normaly there is run capacitor connected on series with the start winding.
is that capacitor used to delay the flux of the start winding? so there is flux on run winding then on start winding?
also i noticed that the motors which drive light loads '' fan motors'' and it has only one speed ''high'' has no run capacitor, only centrifugal switch and some times start capacitor.
is that because motor with run capacitor stronger than the one without, when it is running at low speed or because the motor without will stall when it is loaded and running ot low speed or it is the design?
please advice
Hobbies - HAM Radio - New Member United States - Member - New Member Hobbies - Hunting - New Member
Re: single phase motor
06/19/2008 12:25 PM
Over simplified--Induce potential difference(from the stator) in the rotor--Current lags the voltage by about 90 degrees. The rotor current creates it's magnetic field 90 degrees to the stator field. Now all you have to do is to start it rotating either way.
The way you start it turning doesn't matter a whole lot--We had a hay elevator when I was a kid that you would plug in and turn the head pulley to get it to run--It would run which ever way you started it.
Those who believe in telekinetics, raise my hand --Kurt Vonnegut Jr.
06/20/2008 7:40 AM
