Previous in Forum: single phase motor   Next in Forum: Power plant expansion
heat element sizing or BTU cal
06/19/2008 11:22 AM
I need to calculate the BTU's needed for sizing the heating elements to heat a jacket water system to 90 - 110 deg f. It has a tank that is 12" wide x 36" long x 24" deep, plus 50 gal of piping and jacket water. The circulation pump has a 75 GPM capacity. can anyone help me with the equation need to calulate this.
thanks hippy tech
If you are going to do something. Do it right or don't do it at all.
Good Answers: 97
Re: heat element sizing or BTU cal
06/19/2008 11:53 AM
Need more information:
What temperature gain is required?
06/19/2008 12:23 PM
the temperature gain will be minimal. it it a closed loop system and it is used for maintain temp. the product (candy) will be at temp and the hot water system is only needed to keep it in liquid form. the only time the gain will increase is when the system needs make-up water. the make-up water will be at 60 deg f(city water) and only 1/8 of thanks capacity. and am installing a second element to come on line for start-up, after maintenance, and when make-up water needed.
Good Answers: 266
06/19/2008 12:45 PM
Secondary heating unit is unnecessary. Size your heater for start up time then use controller to maintain temperature.
(Gallons X Temp. Rise(ºF)/ 372 X Heat-up Time(hrs)) X 1000 = watts
1 gallon = 231 in³
06/19/2008 12:50 PM
thanks ozzb i believe that will take care of my issue.
Register to Reply 4 comments
bwire (1); hippy tech (2); ozzb (1)
You might be interested in: BTU Meters, Ball Transfer Units (BTU), AC Power Cords
