I am in the process of having a new home designed and need help in determining the most cost effective insulation option for the home. I am building a geodesic dome, and can actually have the walls/ceiling (as they are one in the same) be whatever thickness is needed to house the insulation. I live in the southeast, with about as many heating degree days as cooling degree days - about 3500 of each. I am looking into fiberglass batting, as I believe I can install it myself with the help of a few others, but I am also interested in looking at foam insulation, particularly soy based. From what I have read, it has superior sealing qualities, and since it fills all cracks and crevices, stops infiltration best. However, I cannot install it myself, and it seems the cost is going to be more than I am paying for actual dome structure - by a LOT.
I want a very energy efficient home, so I am considering a minimum of R 40 and would like R 55. I am also planning to install a geothermal heating / cooling unit, as I have adequate land to use a horizontal installation that won't price that option out of my reach.
So my question is - is the foam insulation sealing ability overrated or is it really worth 4 times the cost of fiberglass? For the same nominal R value, will I really save enough on energy costs to consider it?
I greatly appreciate any guidance or advice in this matter. I can't move forward with the layout of my house until I solve the insulation issue as this impacts the thickness of my structure.
Thanks!
