Previous in Forum: Root Valve   Next in Forum: hydraulic generators with wind turbines
Hydraulic pump pressure
06/22/2008 10:30 AM
I am building a wind turbine system to produce electricity. It is a little bit unconventional in so far as I am planning to use a hydraulic generator on the ground driven by a pump attached to the turbine on top of a mast. I have been looking at Harrison Generators(www.harrisonhydragen.com/mas_specs.htm). They have a 10KW hydraulic generator which they say needs 22 HP to drive it. It also needs 83 ft lbs of torque and 3600psi system pressure. Question_Is it possible to get a relatively slow turning pump that could be connected to the turbine and would pump oil down to a hydraulic motor to produce the power required to drive the generator.
All help appreciated
Pathfinder Tags: Hydraulic turbine Gen
Re: Hydraulic pump pressure
06/22/2008 11:20 AM
It seems to me you can always gear something to (theoretically) get the right rpm.
The real question is ... have you got enough power from the turbine to drive it?
'Cos if you havn't, then no amount of gearing is going to help.
E.G Without enough power, you may get the flow but not enough pressure, or the pressure but not enough flow...the gearing would determine which way around it was.
(Sorry if this is stating the obvious
...but 10KW is a pretty big generator for a wind turbine)
Good Answers: 230
06/22/2008 2:04 PM
Hello miik999
As Del the cat states above, 10 kw is a large electrical output for a wind machine.
The Harrison people are being honest when they state 22 HP input to that generator is required.
22 HP = 16.412 kW, so you can see the unit efficiency is almost 61%, which efficiency would be standard for this type of coupled machine.
The wind turbine location is going to be high, in strong wind stream, well clear of trees, buildings and the like.
If you want more of your wind energy to be more efficient, then a permanent magnet 3 phase alternator coupled directly to the impeller, and mounted at the mast top would be better.
There are several interesting designs of vertical impellers which generate power no matter from which direction the wind arrives, and these don't require electrical sliprings.
Contact Harrison, and ask them for pump details, as they must surely know what other equipment is required with their turbine, since they have been in business since 1969.
Kind Regards....
06/22/2008 3:22 PM
Thank you both for your comments. One other question; Is there an accumulator for hydraulic oil that will hold pressure and release it at a controlled speed. If there is would it be possible to fill the accumulator with a slow but high pressure pump which may not need a lot of power to drive it but would be always filling it when the wind is blowing. If this were possible maybe the steel pole which holds up the turbine could be used as an accumulator tank?
Good Answers: 123
06/22/2008 10:59 PM
My memory of the Harrison system was that it relied on variable displacement, variable speed hydraulic motor. The full 22HP would only be needed if the full load was called for by the generator. At lower loads the displacement of the motor would increase, therefor slowing the alternator speed to maintain the correct frequency. As load increased the alternator would slow and the hydraulic motor would decrease displacement, causing the same amount of hydraulic fluid th spin the alternator faster, maintaining the proper frequency again. If you cannot generate sufficient hydraulic power from your wind turbine, you should be able to add an additional wind turbine and hydraulic pump to the generator system. Google variable displacement hydraulic motors and pumps. Good luck.
Bob
Register to Reply 4 comments
bob c (1); miik999 (1); Sparkstation (1); user-deleted-1105 (1)
You might be interested in: Hydraulic Pumps, Hydraulic Repair Services
