Previous in Forum: GAS TURBINE LOW OUT PUT PROBABLE REASON   Next in Forum: AIR CONDITIONING
Autodesk Inventor - Screw joint
06/25/2008 11:00 PM
I have made a simple screw and nut assembly using autodesk inventor and I am trying to make a dynamic simulation. How do I restrict the motion of the screw rod so that it doesnt come completely out of the nut?
Re: Autodesk Inventor - Screw joint
06/25/2008 11:13 PM
It restrict the joint automatically, but if you change any part later of it, it lost the restriction and you must to do it manually, like regular restrictions... usually I do the joints manually for dynamic simulations, there are less errors...
Good Answers: 94
06/27/2008 4:30 AM
If you have the centrelines of the 2 parts constrained to each other they will stay concentric. The length of travel can be set in the animation command, you start with say, a flush constraint on the ends of the 2 parts then specify the length of travel before the motion either stops or reverses.
06/27/2008 11:46 AM
Dear sir,
Just you refer autodesk site, you ill find there are one day eminar in PUNE,CHENNAI,BAGLURU. I know on 8th of Jualy there is in PUNE find out others which is near to you. There you will gate chance to interact with authry persons of autocad. They are very co ocperative and nice peopels,they will guide you properly.
Thank you.
V.D.DEODHAR.
Register to Reply 3 comments
