Previous in Forum: Alternative Water Source   Next in Forum: rejuvinating "greying" black plastic
10 comments
Egypt - Member - New Member Engineering Fields - Mechanical Engineering - New Member
Graphite Heater
06/26/2008 2:41 AM
is anybody can tell me what are specifications of power supply used for graphit heaters? and how can i calculate required ampere and volt for a specified graphite heater?
No God but Allah
Re: graphite heater
06/26/2008 4:25 AM
Please provide information about the context in which these heaters are to be used.
Re: graphite heater
06/26/2008 5:07 AM
these are graphite bars with a 16 mm diameter & 230 mm length, I want to use them as heaters
No God but Allah
Re: graphite heater
06/26/2008 7:34 AM
What fluid is in contact with them and at what temperature and pressure - air? Water? Petrol?
Re: graphite heater
06/26/2008 8:54 AM
medium is air & temperature : 700 C & pressure : atm
No God but Allah
Re: Graphite Heater
06/26/2008 10:21 AM
YOU MUST SEE "PROJECT CAMELOT " on YOU TUBE!!!!!
Re: Graphite Heater
06/27/2008 6:09 AM
One thing you may want to keep in mind is graphite's threshold of oxidation is around 600 °C. Most graphite heating applications are used in vacuum or inert atmosphere furnaces.
Re: Graphite Heater
06/27/2008 7:39 AM
Quite. At the OP's 700degC, the graphite will turn to CO2 over time at this temperature. So the project sounds like a non-starter so far in terms of the longevity of the heating materials.
<rant>
It would be so much better if the readership didn't have to tease the information slowly out of OPs.
</rant>
Re: Graphite Heater
06/27/2008 7:44 AM
Yea, at that temperature the rods aren't going to last long unless you pull a vacuum or backfill with N2 (preferably both and hold it in the low millitorr range). Most I've seen use 208V single phase and monstrous current. Measure the resistance of the rods and calculate your max current. Ohms law for DC circuits won't be exact, but it will put you in the ballpark.
Emergency night landings...as you approach the ground, turn on your landing lights. If you like what you see, leave 'em on. If not...turn 'em off.
Re: Graphite Heater
06/27/2008 10:19 AM
thank you all for this precious informations, i'll try .......
thank you again
No God but Allah
Re: Graphite Heater
04/28/2012 2:48 AM
CR4 ADMIN: Deleted Post
Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
Register to Reply 10 comments
Anonymous Poster (2); coal1986 (1); engabdou1 (3); Flying boots (1); PWSlack (3)
