Previous in Forum: SF Induction Motor   Next in Forum: Google unsubcribing
Pressure Sensor Switch Application
06/26/2008 11:25 PM
which one pressure sensor can be used in between both hard surface and according the tested pressure date to control other circult power on/off
Good Answers: 230
Re: pressure sensor switch application
06/27/2008 1:18 AM
Hello Guest,
I translate your Question as: "I want to know of a single pressure sensor, which can be used between two hard surfaces, and according to the sensed pressure, send data to control another circuit - to power that circuit either on or off, dependent on the data sent".
Now I may have made some errors in my translation of your Question.
Please advise the correctness of my Translation.
Reply with
Kind Regards....
Canada - Member - New Member
Good Answers: 11
06/27/2008 11:09 PM
If your translation is good (legibility is excellent+++) in explaining the requirement, there are quite a few choices, depending on the application.
Re: Pressure Sensor Switch Application
06/27/2008 11:43 PM
Are you asking about a load cell? You want to determine the force exerted by the two "hard surfaces"?
d
doug johnson (1); gigaconcept.com (1); Sparkstation (1)
