Previous in Forum: Electric Wiring and Coils   Next in Forum: Requirement of power supplies
What Do the Letters in IP Codes Represent?
06/27/2008 7:53 AM
What does the addition of a letter after the first two numbers indicate? I have one for dust/water written as IP6K6K. I understand the 6's but what do the K's specify?
User-tagged by 1 user
Re: More info requested on IP coding
06/27/2008 9:45 AM
Wikipedia has some info here about K ratings. Seems to be a German add-on to the standard.
This site has info about a third digit.
08/22/2011 5:59 AM
CR4 ADMIN: Deleted Post
Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
Re: What Do the Letters in IP Codes Represent?
06/27/2008 11:00 PM
IP code means International Protection and it also mean Ingress of Protection.
IEC 60529 is genereal standard for IP code.
4.1 Arrangement of the IP Code
IP 2 3 C H
Code letters I
(International Protection)
First characteristic numeral I
(numerals O to 6, or letter X)
Second characteristic numeral
(numerals O to 8, or letter X)
Additional letter (optional) 1
(letters A, B, C, D)
Supplementary letter (optional)
(letters H, M, S, W)
Where a characteristic numeral is not required to be specified, it shall be replaced by the
letter "X" ("XX" if both numerals are omitted).
Additional letters and/or supplementary letters may be omitted without replacement.
Where more than one supplementary letter is used, the alphabetic sequence shall apply.
If an enclosure provides different degrees of protection for different intended mounting
arrangements, the relevant degrees of protection shall be indicated by the manufacturer in the
instructions related to the respective mounting arrangements.
Details for the marking of an enclosure are given in clause 10.
4.3
The following examples are to explain the use and arrangement of letters in the IP Code.
Examples for the use of letters in the IP Code
For more comprehensive examples see clause 9.
IP44 - no letters, no options;
I PX5 - omitting first characteristic numeral;
IP2X - omitting second characteristic numeral;
IP20C - using additional letter;
IPXXC - omitting both characteristic numerals, using additional letter;
IPXI c - omitting first characteristic numeral, using additional letter;
IP3XD - omitting second characteristic numeral, using additional letter;
IP23S - using supplementary letter;
IP21 CM - using additional letter and supplementary letter;
IPX5íIPX7 - giving two different. degrees of protection by an enclosure against both water
jets and temporary immersion for "versatile" application.
08/21/2011 7:52 AM
07/01/2008 8:11 AM
Thanks for the replies. I searched the threads for info on the letter designations prior to asking the meaning of the added "K's" after the two digit IP ratings (IP6K6K). I was informed the added K's are from the German DIN standards and specify the testing device, conditions,and duration, and water flow, pressure, and temperature. 6K and 9K are different in that 6K specifies water and 9K high pressure steam for the test procedure. Also, the type of vehicle and area to be tested are identified.
Anonymous Poster (1); electricaleng (2); JohnDG (1); tlmkr1605 (1)
