Previous in Forum: System Grounding   Next in Forum: What Do the Letters in IP Codes Represent?
Electric Wiring and Coils
06/27/2008 2:02 AM
I found one website please cheack it and tell me Is this website is usefull for me to get information about Wiring and coils.
http://sagharborind.com/MoldedCoils.asp
User-tagged by 1 user
tie wire
06/27/2008 3:38 AM
tie wire
Polythene building film will provide a moisture and vapour barrier for use with slab on ground construction. The low density polythene film membrane is available in a range of thicknesses and roll sies, and can be used as a concrete underlay and as a curing blanket.
The concrete underlay membrane will prevent moisture from penetrating beneath the slab. This prevents damage to floor coverings from rising damp and mould.
It also gives a stronger and denser slab, prevents concrete wastage and slows the curing process. It resists attacks by acid or alkaline soils and does not deteriorate when it comes in contact with water. Polythene building film also facilitates and speeds the removal of formwork.
Used as a curing blanket, the film gives a stronger slab by preventing the escape of heat and moisture, thereby slowing the curing process.
http://www.tiewire.net
Hobbies - Musician - New Member Engineering Fields - Manufacturing Engineering - New Member
Re: tie wire
06/29/2008 2:43 AM
Tie wire...what the....???
Guest....what is it that you are looking for?
Valve coils? Pretty simple. Just 2 wires for AC or DC. Usually doesn't matter how you hook them up. If for DC it happens to show + and - terminals then hook the positive side of the control circuit to the + terminal and the negative to the - terminal.
The site you referenced shows this type of coil.
Please reply if the above isn't what you wanted and you need further help.
Kind regards.....Jeff
Courage is not the absence of fear, but the inner resolve to rise above it....or the inane lapse in judgement brought on by copious imbibitions....Egre Flagrus
Canada - Member - New Member
Good Answers: 11
Re: Electric Wiring and Coils
06/27/2008 11:12 PM
We have to guess if you found this site useful to you?
gigaconcept.com (1); snygolfgs (1); tiewire (1)
