Previous in Forum: Fire Protection in Computer (IT) Server Closets   Next in Forum: Electric Wiring and Coils
System Grounding
06/26/2008 8:43 PM
anybody help me please...
when we applied Solid Grounded, Resistance Grounded, Reactance Grounded and Ground Fault Neutralizer
thank you very much
Good Answers: 230
Re: System Grounding
06/26/2008 9:48 PM
Hello Guest,
There are so many variables, you need to narrow the scope of your question.
Please reply, with
Kind Regards....
06/28/2008 2:48 AM
You may be referring to grounding transformers? If so please consider the following:
> For Zigzag Grounding Transformer: the neutral of a zigzag transformer must be solidly grounded when applied to low voltage system, while it must be resistance grounded when used in medium voltage system.
> Wye-Delta Grounding Transformer: The wye-side must be connected to the line with the neutral grounded through a resistor. The delta-side must be closed to provide a path to the zero sequence current.
> Solid Grounding: Applicable to low-voltage and medium voltage systems greater than and including 13.8KV.
> Resistance Grounding: Applicable to medium voltage systems below 13.8KV
i. Low-resistance Grounding: Used to limit ground fault current to 200 - 400 amperes.
ii. High-resistance grounding: Used to keep a faulted feeder functioning during a ground fault until an orderly shutdown of equipment can be effected; and to keep the ground fault related damage to minimum.
Hoping this simple reply will help you. Good day to you.
Good Answers: 93
06/28/2008 11:19 AM
The question about Grounding is further discussed on another thread under the title Earthing and Grounding, or something like that. Sparkstation gave a great answer and the discussion goes on to mention isolated grounding, wire coding, and other nuances. The new CR4 member who responded spoke of grounding in ways I have no experience with, but found fascinating.
You don't get wise because you got old, you get old because you were wise.
common_tie (1); Sparkstation (1); Transcendian (1)
