Previous in Forum: Yield for Square Tubing   Next in Forum: troughed belt conveyor standards
Pumps and Slurries
07/01/2008 9:42 AM
Hi all,
I want to ask you about a pump consideration I need to do.
For a project area I am involved, we have a sump pump and consider two cases: rainfall ( 0.63 m3/h), and a spill or leak of 20%, in volume, of one of the tanks (this is the mandatory flow 55 m3/h).
The problem I have is the diference between the viscosities 1.3 cP for water and 13 cP for tanks content (slurry).
As I understand will be necesary to "dilute" with water the spill of slurry in order to drive it to the sump, may I consider it as a "heavy liquid" and not a slurry in order to calculate the pump?
Could you give any idea about the question?
Re: Pump consideration
07/01/2008 11:37 AM
Tell us more about the mystery chemical slurry.
07/01/2008 11:51 AM
No problem, the slurry come from a silver-gold mine and are send to the tailings dam. It have 50/55 % of solids in water. But I understand that will be "pushed" in to the sump pump with water.
May be I can consider as "heavy liquid"?
Regards
Ernesto
07/01/2008 12:26 PM
Use two pumps and two waste streams designed according to their respective viscosities rather than "blending" the discrete waste streams into one.
Re: Pumps and Slurries
07/01/2008 11:53 PM
No problems the slurry pump requirements will also handle water. We regularly flush our tailings lines with water using the pumps in the tailings line. You will need to do your calcs for the sump pump based on the heaviest liquid properties that the pump is going to handle.
Pumping water with a slurry pump may not be the most efficient use of a slurry pump so I would consider which liquid you would be pumping most of the time. If you are in a tropical area where it rains every day for 6 – 8 months I would go for two pumps one for the slurry and one for the water. Water pumps for less than 1 m3/hr should cost significantly less than a slurry pump 55 m3/hr.
The best reference material for slurry pumping that I have come across is the Weir Warman "Slurry Pumping Manual" available from the following link,
http://www.weirminerals.com/weirweb/minerals/home.nsf/vwDownloadFiles?OpenView&cat=SoftwareProducts
Regards Henry
"You can't get the wood you know."
07/02/2008 4:14 AM
Hi ernesto1962
You should use one slurry pump to pump up both the slurry and the rainfall.First you have to know the max solid size that will pass the pump impeller, then you should select your pump based on thr following:
-Total discharge flow in cubic m/h
-Total dynamic head in m
-Max solid size in mm
Most likely you will be in need for a submersible,open impeller of vortex type.
You,also,can use a diaphragm pump or a progressive cavity pump.
In all cases you should tell the pump manufacturer about nature of slurrey that you are using.Mono pumps ,allweiler a.g.,and tsurumi pumps are a screw pump manufacturers that you can refer to.Welden pumps is a diaphragm pump manufacture.
Best Regards
Sayed Sarhan
Anonymous Poster (1); ernesto1962 (1); Henry Crun (1); sayed sarhan (1); user-deleted-9 (1)
You might be interested in: Sump Pumps, Vacuum Greases and Vacuum Pump Oils
