Previous in Forum: International conduit fittings   Next in Forum: mobile phone jammer
United States - Member - Member Engineering Fields - Manufacturing Engineering - Member Hobbies - Fishing - Member
Looking for a material testing lab in the USA
07/01/2008 4:54 PM
Anyone know of a material testing lab that has the capability to test galvanized (hot dipped) sheet metal to determine chemical composition, corrosive impurities, coating mil, etc.?
I will need an evaluation to determine the elemental presence of anything other than the expected oxides of iron, zinc or aluminum. I specifically looking for any corrosive contaminants and to verify material and coating application meets ASTM requirements.
The use of an EDS (energy dispersive spectroscopy) or similar technology would provide me the proper analysis to compare to test results received from the material manufacture / provider.
I am experiencing a corrosion issue that the manf / provider has tested and sent the results to me. I would like a third party analysis to confirm the findings.
Any info would be appreciated - Name, Location, capability, accuracy, accreditation, etc.
You may post here or e-mail me.
THANX!!
"Stepping up to the plate" is not enough, you have to swing to get a hit!
Pathfinder Tags: corrosion analysis EDS Test lab
Re: Looking for a material testing lab in the USA
07/02/2008 1:51 AM
Stork Materials Testing & Inspection www.storkmt.com
07/02/2008 8:27 AM
Chicago Spectro Service Lab Inc.
chicagospectro.com
6245 S Oak Park Ave
Chicago, IL 60638
(773) 229-0099
GWebMedia.Net
Good Answers: 243
07/02/2008 8:28 AM
I used this company extensively on a steel mill startup until I could develop inhouse capabilities. Their work was of sufficient quality to prevail in sevral disputes with major OEMS.
All contact info is on the home page here.
http://www.modernind.com/
milo
07/02/2008 8:45 AM
Thank you to all - I have contacted each for review.
CAM
Hobbies - DIY Welding - pipewelder
07/02/2008 9:20 AM
I use Applied Technical Services in Marietta, Ga. (Atlanta area) http://www.atslab.com/ they probably can help you.
pipewelder
pipewelder
07/02/2008 10:28 AM
Thanks PW - They list an EDS on their site which is what I need for an accurate comparison.
CAM
Register to Reply 6 comments
Anonymous Poster (2); Camilliontwo1 (2); Milo (1); pipewelder (1)
