Previous in Forum: Compatible Spare Parts for Cereal Mills   Next in Forum: Small 12 vdc Motor/Pump Assembly
Moments
09/12/2006 12:07 PM
Why should the turning force or moments increase when distance increases? What does distance have to do with it? Please enlighten.
Moment
09/12/2006 4:02 PM
I forget who said it, but there is a famous quote once said. "Give me a lever long enough and I can move the earth". In order to rotate, a torque is required. Torque is defined as force x distance. If you are trying to twist off a cap, you need to apply a certain torque to it. So that tourqe is an unchanging value. If you can produce it, you're all set. That said, if you look at the formula, its easy. Increase the distance and the force is less. Also, if you increase the force, the distance needs to be less for a given torque.
Re:Moment
09/12/2006 10:37 PM
A. It was Archimedes, B. Not only turning or torque, it is also true for any force applied, The greater the arm is,(distance) lesser force is required to move an object.(remember vectors?). Wangito
Never trade luck for skill.
Good Answers: 247
levers
09/12/2006 10:57 PM
Gearing, pulley systems, and levers all work on the same principal. You can think of a pulley, for example, as an infinite number of small levers radiating out from the center.
If you are looking for a more theoretical basis, in other words, if you are asking why does a lever work, then it has to do with the conservation of energy. The amount of work (distance * force) at the input has to equal the amount of work (distance * force) at the output.
The Engineer
Good Answers: 129
Moments
09/13/2006 3:55 PM
You know, I've been wondering what moment meant for a while now. So it's related to the force necessary to cause a movement. I've seen it in moment of inertia, dipole moment, momentum, etc. Makes much more sense now.
Register to Reply 4 comments
Anonymous Poster (1); Bayes (1); Blink (1); wangito (1)
