Previous in Forum: chemical energy resourses   Next in Forum: Viscosity for Ca(OH)2 solution
Pedal Spinner
07/03/2008 8:21 AM
Why does my fine mesh, metal coffee filter basket allow water to flow through from the outside when immersed, but will not allow trapped air to flow through, from the inside out, when inverted and submerged?
Good Answers: 143
Re: Pedal Spinner
07/03/2008 9:07 AM
Have you read Quo Vadis ?
Re: Pedal Spinner
07/03/2008 9:43 AM
Surface Tension. It's got a lot to do with the pressure in the air bubble, its size, and the depth of submersion. The bubble pressure, the surface tension and the bubble diameter are inter-related by a simple equation. The correct equation to use depends on whether there are two liquid/air interfaces, as might be the case with a blown soap bubble, or a submerged bubble in this case, which only has one.
Squeeze it hard enough, i.e. increase the bubble pressure, and the air will then come through. This is the principle behind air flotation systems as may be found in sewage works, among other places.
Re: Pedal Spinner
07/04/2008 11:25 AM
Can you please direct me to a website that contains the formulas for these calculations?
Good Answers: 183
Re: Pedal Spinner
07/04/2008 2:34 PM
Try to find a thread about drops As far as I remenber I gave some indication on the superficial tension aspects and calculations.
Good Answers: 143
Re: Pedal Spinner
07/06/2008 8:39 AM
My question about Quo Vadis was serious.
Anonymous Poster (1); nick name (1); PWSlack (1); TVP45 (2)
