Previous in Forum: different between 2 wire and 3 wire   Next in Forum: mtech
dust measurement
07/03/2008 9:08 AM
hi
am searching of a instrument that could measure dust in the air (in a clean room).
any sugestion.
Safety - Hazmat - Environmental, Safety & Health Manager Hobbies - Musician - Theremin (That about says it all...)
Good Answers: 19
Re: dust measurement
07/03/2008 9:47 AM
TrinhTT,
There are many, many instruments that you can choose from...
A few questions to qualify your needs:
When you say you have a "clean room", how "Clean" is it?
What classification system do you follow (US FS209D/E, ISO 14644-1, BS 5295)?
Do you need to perform spot measurements (i.e., with a battery-powered, handheld device), or do you want a fixed (line-powered) instrument for continuous, remote monitoring?
A good starting point for you might be to check out the following link:
http://www.particlecounters.org/
They have information on, and review of many of the particle counters on the market...
Just my $0.02...
07/03/2008 9:53 AM
thanks for your answer I didn't now of all this fact that I should check.
07/03/2008 10:22 AM
o.k. here the situation:
am searching for a instrument that would be fixed in a room that will a continuous reading and if the dust in the air it,s too high it will start a alarm.
alarm will be actved by a relay or a output digital signal.
07/07/2008 5:00 AM
The question <When you say you have a "clean room", how "Clean" is it?> requires a quantitative answer before proceeding.
Register to Reply 4 comments
PWSlack (1); The JMAN (1); TrinhTT (2)
