Previous in Forum: 4x Electrical Box slope   Next in Forum: skin effect
Welding
07/03/2008 11:07 AM
Hi friends,
I have some PLC controlled machines & I want to do welding(arc type) to some places on these machines; Please tell that if I do this; Is there any problem to PLC units?
Also I heard that Earthing of machine should be removed while doing welding to machines. Is it true.Please help to clear this doubt.
Thanks in advance...
Re: Welding
07/03/2008 11:20 AM
Any doubt remove the PLC, you may also have a problem with and sensors and motors.
Re: Welding
07/03/2008 2:12 PM
I agree except I'd remove your first two words...
Re: Welding
07/04/2008 7:41 PM
true
Hobbies - HAM Radio - New Member United States - Member - New Member Hobbies - Hunting - New Member
Re: Welding
07/03/2008 2:32 PM
We see a lot of maintenance around PLCs including welding--It is amazing how hardy and how few problems we have had--A couple of analog sizing eyes and optical encoders have been damaged from welding, but the damage is usually from feet and hammers and pry bars. It also depends on who is doing the welding and where--I've caught guys welding through bearings with bad ground placement(I suspect that is how the encoder went--I tore it open and there was a visible film from the shaft seal/heat that was getting smeared on the glass).
We hardly ever get notified of maintenance and welding on or around PLC equipment prior to it being done and we are purely reactive-BUT if it was up to me I would take the time to guarantee no damage to the processor or any I/O and cover or remove it(the only downside may be the disposition of the processor battery, but may give you a good chance to plan for, and change it).
The contract maintenance technicians on rolling stock/heavy equipment ALWAYS disconnects the ECM(s) prior to even simple service requests and an ounce of that prevention.........
Those who believe in telekinetics, raise my hand --Kurt Vonnegut Jr.
Re: Welding
07/04/2008 1:44 PM
You could remove the PLC but I wouldn't, turn them off instead nor would I remove grounds,the most important thing is to connect your welder ground in such a way as not to pass current through things that won't like it.Connect the welder ground as near to work as possible,Have welded on plc controlled equipment many times.
dg1258 (1); Kilgore Trout (1); phoenix911 (2); user-deleted-1105 (1)
