Previous in Forum: Noise control for lab sized high vacuum pumps   Next in Forum: Mechanical verses Solidworks
Car Motors Again
07/03/2008 2:13 PM
Ok I Got another Ideal for a car motor, Is there anyway to make a high rpm Hydraulic motor for a car?
Its All BS
Pathfinder Tags: Hydraulic motor
Re: Car Motors Again
07/03/2008 5:04 PM
Maybe... but take it back a step before thinking about the motor. Where's the high pressure/high flow hydraulics coming from to drive it? Crack that one first.
07/03/2008 5:46 PM
You can find several Hydraulic Motors that go as high as 3,000 RPM at this site:
http://www.hydraulicspneumatics.com/Directory/Default.aspx
Go to the "Motors, Hydraulic" link there to see all that are available and the specifications for each manufacturers design.
As mentioned, they do need a Pump to supply them and that Pump must be driven by some method.
Bud Trinkel
07/04/2008 7:45 AM
Well, hydraulic transmission systems were employed in railway locomotives starting more than 50 years ago. The BR class 02, class 22 and the Deutsche Bundesbahn class V200 are good examples of the application of hydraulic power transmission to a self-propelled vehicle.
Note that the primary power was supplied by an appropriately-sized diesel engine in each case.
Good Answers: 16
07/04/2008 10:09 AM
Many larger lawn mowers have hydrostatic transmissions and will be an inexpensive source for your experimental equipment.
Specializing in Dynamic Weighing Systems for Powder and Bulk Solids Handling
Register to Reply 4 comments
BudT (1); Delmar (1); JohnDG (1); PWSlack (1)
