Previous in Forum: Current flow.   Next in Forum: please reply tertiary winding
PT100 or RTD sensor
07/07/2008 7:03 AM
I HAVE A FEW MOTORS WITHOUT PT100 OR RTD SENSOR AND NOW I WANT TO ADD THEM THE a/m SENSOR . HOW CAN I DO THIS?
Re: PT100 or RTD sensor
07/07/2008 7:18 AM
Without using CAPS LOCK, please explain the term a/m for the newer reader.
07/07/2008 9:27 AM
a/m mean:above mentioned . in my message it reffers to PT100 or RTD sensors
07/07/2008 10:00 AM
Farshid, you would like to add PT-100 sensors to the motor to read the winding temperature, shaft bearing temperature, i assume so. You should know, in the first place what is the purpose of adding these PT-100's and assuming that you know all, the motors should have sensor pocket to hold the thermowell at the point of measuring and then you need to insert the sensor and connect using proper cable to either digital display or convert PT-100 to milliamps and hook-up to the alarm monitoring system.
Register to Reply 3 comments
farshid farahmand (1); PWSlack (1); shrini (1)
