Previous in Forum: Unexplained force moving Pioneer spacecraft?   Next in Forum: Using technology to combat Terror: Starlight 3.0
Friend of CR4
Vision-based CMM system speeds up car inspection
05/11/2005 9:08 AM
French car-maker Renault plans to use a robot-mounted imaging system, designed by ActiCM, to speed up the inspection process on newly built cars. The vision-based co-ordinate measuring machine (CMM) can inspect and validate an assembled car body in under two hours. Full inspection with a traditional mechanical CMM system takes around 10 hours.
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
The Feature Creep
Accuracy
05/11/2005 9:57 AM
I'm just curious to see if the rate of defects goes up or down. If there is a defect that the robot doesn't know to look for, almost all of products can have it.
"The future is here. It's just not widely distributed yet." -William Gibson
Friend of CR4
Re:Accuracy
05/11/2005 10:04 AM
I don't know if that is a relavent assumption. The traditional mechanical versions would be just as vulnerable to missing defects if proper oversite was not provided during programming and testing.
The Feature Creep
Re:Accuracy
05/11/2005 10:10 AM
My question is more of a trading speed for accuracy. This machine is faster, and I assume more accurate, but where do you draw the line for "accurate enough" with something like an automobile?
Register to Reply 3 comments
