I have found a situation on a buck boost transformer that I am not sure if I should be concerned with . It is a 150KVA, 208 x 480. The input voltages with (1) meter lead on the line and the other on ground are 115/116/118. This seams normal to me. The output voltages, measured the same way are 266/327/227. This seams odd. Measuring voltages from 1 leg to the other, the voltages all seam normal. The input amp readings are 130/245/260. The output amps are all within 10 amps of each other. There have been issues with this system in the past. It is up against its amp limit when they run there large spot welders. Any thoughts?
