I have two little electric scooters (the two chargers supplied with them plugs in to a 110 outlet and it says it is 1200ma on each charger. I am hoping to buy a 15 watt solar panel, a 7 amp charge controller, a 12 volt marine deep discharge battery ( about the size you see in cars) and when the marine battery is fully charged, use a 225 watt inverter (converts the 12 volt to 110) and then use the chargers supplied with the scooter to recharge the two batteries in each scooter. Each scooter has 2 small 12volt batteries hooked together so they are 24 volts for each scooter. Will this work? ( just for information, I accomplished this with the present small solar system I have. I is a 75 watt panel, 3 deep discharge 12 volt marine batteries and a 750 watt inverter and it worked fine) I want to downsize and still make it work. any suggestion? thanks
