Previous in Forum: Oxygen Cleanliness Levels for Submarines and Divers   Next in Forum: Lithium Batteries and Seawater
Miniature Linear Actuator
07/11/2008 6:17 AM
CR4,
Does anyone know where I can find a miniature linear actuator with the following characteristics:
Body type: - cylindrical
Max diameter (most important): - 3mm
Stroke: >8mm
Resolution: <0.5mm
Accuracy: <0.5mm
Force: >2.5N
Velocity: Approx. 5mm/sec
I have have found a lot miniature stepper and servo motors. The closest I found to my specification was a 4mm diameter stepper. However at >€150 each it is too expensive. It seems I would be paying for the resolution and accuracy that I do not require.
Unfortunately I cannot disclose the application yet.
Thank you in advance for your help.
Regards,
J.
Good Answers: 266
Re: Miniature Linear Actuator
07/11/2008 6:53 AM
Good Answers: 96
07/11/2008 11:14 PM
Hi,
If a pneumatic solution will work for you might check Clippard Minimatic.
http://www.clippard.com/
(with a handle like Jonny5, my imagination is running WILD with possibilities as to the use of this miniature actuator).
"Just when I had all the answers, they changed all the questions"
07/11/2008 11:44 PM
Check out radio control servos. Price is reasonable.
They have the accuracy you need, you just need to send it the right signals, not too difficult.....servo testers are available to do just that for a few bucks....
07/12/2008 5:16 AM
Speak with Harry Hogg, Sales Manager, Helical Technology Ltd. on 44 1253 733122.
This Company will Design, develop and manufacture an Actuator to your specification. They are also Spring manufacturers, so they shoud be able to give you a good solution!
Canada - Member - New Member
Good Answers: 11
07/12/2008 8:01 AM
Did you take a look at the Smoovy?
It is pretty close to your specs.
If I remember well, these used to be in the $125 range in 10 quantity, in year 2001, before being taken over by Faulhaber. They used to be RMB, but when they sold off the motors, they changed to Myonic and still supply cool miniature hardware.
Alternatively you could use a small lead screw such as Kerk with a low cost motor and gear head of your choice.
If you can work to change some specs, these unusual actuators may fit your application:
http://www.newscaletech.com/
http://www.migamotors.com/Products.html
Andy Germany (1); davids (1); DCaD (1); gigaconcept.com (1); ozzb (1)
You might be interested in: Linear Actuators, Stepper Motors, Stepper Motor Drives
