Previous in Forum: Current carring capacity of copper bus bar   Next in Forum: GFCI receptacles
Tandem Switch
09/15/2006 1:59 AM
Is anyone here familiar with switches? I am looking for a switch that will control two seperate ciruit simultaneously. ie, if i only have to push one button to close both circuit. And I prefer one that would have the option only Hi or Lo setting, not Off (not sure if there are switches that has no Off position). And also keep in mind that, between the two circuits, one is high voltage, 240V, the other one is for a gas valve, which requires no external power source.
I am trying to design a circuit for a fireplace. It is necessary to have the fan on for safe operation. So I'm trying to figure out a way to make a fool-proof system, so that when the person flicks the switch, it turns both the fan and the burner at the same time. I also have other components in the circuit for safety shut-off. Anyway, if anyone can shine the light in the right direction for me, it would be much appreciated.
Thanks all!!
Pathfinder Tags: electrical switches
Good Answers: 114
Re: tandem switch
09/15/2006 3:16 AM
You don't need a stacked switch per say [though it's obtainium]
You need a Fireye.
You can buy 1 from allen-bradley. Honeywell makes a real trick unit that has spark & flame detection on the same wire, internal relays. I've used 24vac &120vac units, they probably make 240vac too.
Garth
Re: tandem switch
09/15/2006 8:45 AM
Sounds like you need a 3 position double pole, double throw switch (3Pos DPDT). One pole is for the the fan, the other for the valve. Center position all off, up position fan hi & valve on, down position fan low & valve on. If you have a two position valve, wire one coil to the hi position and one to the low position. Newark inOne Electronics Supply is one source.
Re: Tandem Switch
09/15/2006 11:50 PM
You could use a dpdt switch. There is one that will satisfy your requirements
Remember The 343 !
Re: Tandem Switch
09/16/2006 7:41 AM
For your own safety, and those around you, buy a ready-made control.Ad-hoc mechanisms for controlling gas and spark are very dangerous.If you have to ask how to do it, you do not have enough experience to do it. Merely acting on instructions from a web link can get someone seriously hurt or worse.My advice:
This is not a DIY project!
Good Answers: 16
Re: Tandem Switch
09/16/2006 2:48 PM
Sounds like it would be much easier to install a standard switch, and use two relays for controlling the valve and fan.
You can install a latching circuit to prevent the valve relay from energizing until the fan proofs on.
Regards, Delmar Schmidt
Melfi Technologies Houston
dschmidt@melfitechnologies.com
Specializing in Dynamic Weighing Systems for Powder and Bulk Solids Handling
Anonymous Poster (1); Delmar (1); Garthh (1); Jeff (1); silverocks (1)
You might be interested in: Thermostats and Thermal Switches, Circuit Breakers
