Previous in Forum: VCB   Next in Forum: Timers
Rotork Actuator
07/14/2008 6:16 AM
I have problem on MOV actuator Rotork type IQ20 its look mechanical problem on clutching /declutching ,and I want to dismantle it but unfortunately failed to dismantle the hand wheel handle side .So any one can help me on providing service manual for it
Thanks in-advance
Re: Rotork Actuator
07/14/2008 11:38 AM
<Sigh> How about the original equipment manufacturer?
Re: Rotork Actuator
07/15/2008 2:50 AM
Thanks PWSlak
Unfortunately we lost all OEM manual for this type
Hope you will be able to send it
Regards
Re: Rotork Actuator
07/15/2008 9:02 AM
Please check the website of Rotark Controls www.rotark.co.in.
Re: Rotork Actuator
07/22/2008 6:06 AM
Thank you all
I got most the doc available at web site but unfortunately not clear how to dismantle the IQ 20 especially from the hand wheel side .I have tried all the possibility ex I hammered it from the other side no result , I'm worry if there is cir-clip behind or any other locking method. Can any one guide me to dismantle it?
Thank s
Spain - Member - New Member Engineering Fields - Nuclear Engineering - New Member
Good Answers: 25
Re: Rotork Actuator
07/22/2008 7:48 AM
Hi,
Even I'm not very expert on this specific trademark of electrical actuators (I'm more familiar with those Limitorque, Siemens and Auma made or even old Rotork "A" series")
According to your OP, you have a problem with clutch. What is really the problem? Does the actuator function just in motorized position? or you cannot put it in "manual position?
This actuator type are not the most suitable for disassembly starting from handwheel.
Anyway if you have problems with the clutching system you will need to disassembly almost completely the actuator, so you need to begin uncoupling it from the valve and start dismantling the driving block as well as the motor and the connection box.
I'm sure the handwheel must have some locking device, otherwise it would be out of place just when trying to actuate it in manual mode (When you act on the clutch lever, you move upwards all driving column against the spring to engage the handwheel).
I've taken a look on the "Maintenance and Installation Instructions" and found nothing about the handwheel locking details.
Sorry
Re: Rotork Actuator
02/24/2009 9:06 AM
Good afternoon gentlemen
i am a rotork agent,and i am very familiar with the 1Q Range,your problem is the the handwheel is being held diown by a nylon rod,which is accesiable through a cap head screw,however if i had a problem with my car i would take it to a specialist i would not try to do the work myself.
You will have to buy the spares via Rotork ,ie. clutch spring and cam which is probably damaged to to excessive force whilst trying to engage the handwheel.
Please refer to the Rotork website to see possiable local representation
Regards
Anonymous Poster (4); Kwetz (1); PWSlack (1)
