Previous in Forum: die coating   Next in Forum: Browns Gas for Increased Fuel Efficiency, True?
10 comments
MS pipes for chilled water
07/14/2008 7:59 AM
I'm going to replace the current PVC chilles water pipes to steel pipes, whic type is better MS steel or stailess steel ans why. Also which type is cost effective on the long run since we will be responsible for maintaining =the system for the next 10 years.
Good Answers: 97
Re: MS pipes for chilled water
07/14/2008 4:48 PM
PVC
07/15/2008 11:17 AM
Thanks, but I mean which type is cost effective MS steel or SS.
07/15/2008 12:44 AM
Why Are you replacing them,Are you putting in a new system and are we talking AC units? If Its AC units I would stay with PVC,MS steel will rust and stainless is very Expensive.
Its All BS
07/15/2008 11:21 AM
Thanks, we are replacing PVC due to many break downs in the piping system. it is industrial chilled water system for printing machines. the working pressure is 5 bars, the pipes can take up to 13 bar, still it fails on frequently. we have alot of leaks, pipes burst, elbow-pipe join breaks.
07/15/2008 12:59 PM
Have you considered PEX? It's flexible, can take some pressure and is easy to plumb with "shark bites"
Hobbies - DIY Welding - pipewelder
07/15/2008 1:14 PM
Hello, I would recommend that you use mild steel, either welded or with victaulic connections from 2.5" and above and use threaded connections below 2" diameter, It will last you many years and would be way more cost effective than stainless steel. The trick to using mild steel for chilled water is to have a vapor barrier between it and the insulation. If you do not have this the pipe will constantly drip and make the pipe rust from the outside. I currently have about 12 miles of mild steel piped chilled water in the paper mill that has been in service for 12-15 years and we have had no problems with it. Be very careful using galvanized pipe for chilled water as it can react unfavorable to certain chemicals in chillers and actually cause problems with the tubes.
pipewelder
pipewelder
07/15/2008 2:24 PM
Thanks for the info.
07/17/2008 4:48 PM
Why does the PVC pipe failed? Frozen pipe? External damage? Sudden pressure surge in system? Improper installation?
Pineapple
07/18/2008 9:21 AM
Nothing confirmed, but most properly due to teh follwoing;
  1. bad installation
  2. Sudden change in pressure as we used fixed speed pump, while consumption flow of chilled water is variable.
  3. weak pipe supports.
Good Answers: 97
07/18/2008 12:20 PM
T add comment of your original post:
As a qualifying of "cost effectiveness" thoroughly consider the re-installation of PVC but maybe up grade to a stronger schedule #80 for instance. Strengthen the supports and install a pressure regulator.
Anonymous Poster (1); bwire (2); DJCharlie50 (1); duraidali (4); Pineapple (1); pipewelder (1)
You might be interested in: Heat Pipes, Stainless Steel Alloys, VU Meters
