Previous in Forum: Diamond dressers?   Next in Forum: CFM FOR 6" BORE CYL WITH 50" STROKE
Hertzian contact stress
07/14/2008 1:03 PM
As shown above, the link (blue) is connected to two pins A and B (red).
Force is applied by the pin A on the link along the x direction purely.
A reaction force is expected at the corresponding point of contact between the pin B and the link
I am told that the compressive stress produced around the contact region of the pin B and the link, is explained by the hertzian stress.
I am unable to find any literature that might give me the method to calculate the contact stresses using hertzian stress criteria.
  1. Is hertzian stress criteria the right way to approach this problem?
  2. If yes, could someone please tell me how.
Thank you.
Pathfinder Tags: Hertzian contact stress
Good Answers: 18
Re: Hertzian contact stress
07/14/2008 2:54 PM
How's about what Wikipedia has to say about Hertzian Contact Stress?
Good Answers: 74
07/14/2008 7:37 PM
Hertzian stress criteria was developed for two spherical surfaces of different radii bearing against each other.
In the case illustrated, there are two cylindrical surfaces bearing together. If they are accurately machined to fit, the bearing stress should be Fx/td where t is the plate thickness and d is the diameter of pin.
Bruce
Good Answers: 58
07/15/2008 6:26 AM
From my recollection, hertzian stress is a result of both normal and shear stress in curved surfaces. Your link example illustrates normal stress only. If you were to apply an axial force on a pin while the link was loaded, you would generate shear stress at the pin/link interface. In the Hertzian regime, the maximum shear stress would occur as two parallel lines along the axis of the pin. Hertzian stress is most often computed for the stress between two spherical surfaces of different radii under combined normal and shear stress. In that case, the maximum hertzian stress ocurrs along a circular path.
Good Answers: 94
07/15/2008 8:46 AM
Hertzian stresses apply to static one directional loads as well. They are used to determine i.e. the stress concentration in the corner of a groove in an axially loaded shaft or point loads. There are look-up tables for all sorts of situations, I can remember seeing the tables in my Newnes Engineers Handbook which, unfortunately, I don't have with me but I guess the tables would be available elsewhere.
This thread discusses hertzian stresses of a cylinder in a hole & may help.
07/15/2008 8:59 AM
'Hertzian stress' is often used in lieu of 'contact stress', regardless of Hertz's original solution for sphere contact. In this sense, you are corrent on point 1. But your point 2 amounts to a few weeks' university lecture time. Too much info to share over the internet.
Consider buying a handbook on mechanics (many good ones to choose from). Make the investment and save yourself the time. You likely won't find the comprehensive calculations on-line, only sporadic info and puzzle pieces...
08/28/2008 10:04 AM
Hi!
If the problem is still to be solved, I have some comments.
The consideration for contact stress would depend on how loose is the fit between the pin and the link.
Do you have dimensions and loads?
regards
dc-link
Register to Reply 6 comments
Anonymous Poster (2); ba/ael (1); Bill (1); Nigh (1); welderman (1)
You might be interested in: IC Pin Probes, Angular Contact Bearings, PIN Diodes
