Previous in Forum: deep well casing leaks   Next in Forum: Hook-up Details
8 comments
search
07/17/2008 3:52 AM
I have lost my "search" icon on my desktop. The run, help and support, and control panel icons are still there but I have lost the search icon. Can anyone help? Thanks James
"WORKS FOR ME"
Italy - Member - Founding Member Technical Fields - Marketing/Advertising - Founding Member Engineering Fields - Manufacturing Engineering - New Member
Re: search
07/17/2008 6:29 AM
Go on start and you will find the search option.
“Being a woman is a terribly difficult task, since it consists principally in dealing with men.” Joseph Conrad
Re: search
07/17/2008 7:54 AM
Rosy. Thats what I was trying to say, it is NOT there! James
"WORKS FOR ME"
Re: search
07/17/2008 9:20 AM
2 quick fixes ... http://www.copernic.com/en/products/desktop-search/download.html free for home use, better (IMHO) than XP search.
Did you uninstall some software lately? Try this to restore it ...
Open a shell (start -> run -> cmd):
regsvr32 /i C:\Windows\Srchasst\srchui.dll
regsvr32 /i urlmon
regsvr32 jscript
right-click windows/inf/srchasst.inf > install
Good luck,
Mike
Re: search
07/17/2008 2:04 PM
If I understand your problem correctly (and I may not!) let's try this:
  1. Click your Start button.
  2. Once the Start window comes up, put your pointer up in the blue area at the top of the Start window.
  3. RIGHT click. A little "Properties" menu should open. Click on it.
  4. Click on the "Start Menu" tab.
  5. Select the "start menu" button (if it's not already selected) and then click on "Customize".
  6. Click on the "Advanced" tab.
  7. In the "Start Menu items" list, scroll down until you see the box for "Search". If it's not check marked then check mark it!
  8. Click "OK".
Hopefully this helps.
Re: search
07/17/2008 4:40 PM
Great, I tried just in case it will happen to me in the future and it works!!!
thanks guest!!!
Rosy
Re: search
07/18/2008 2:56 AM
THANKS ! THANK YOU VERY MUCH! IT WORKS! James
"WORKS FOR ME"
Re: search
07/18/2008 10:43 PM
One additional repair or workaround one can use, if your system is using Vista, is to download and use a search gadget. Mine has radio buttons for all the major search engines currently on the net.
The apparent cycles of action are: Start, Change, Stop. The true cycle of action is: Create, create, create, etc.
Good Answers: 68
Re: search
07/18/2008 2:38 AM
Hello James P. Hollen:
'ROSE' was right. Richt click start and or My computer.
Let us know how you get on. I am trying to find out how to get a new Search link on the desktop for you.
babybear.
Register to Reply 8 comments
Anonymous Poster (1); babybear (1); HapE2bhere (1); James P. Hollen (2); Rosy (2); Tinker65 (1)
