Previous in Forum: Tube filling machines for manufacturing tube heaters   Next in Forum: How to calculate BTU/hr to heat water?
MathCAD
07/21/2008 9:52 AM
I use MathCAd to calculating but today I have a problem:
My problem is using matris I take some data in excel (vizcosity density etc) files and I want to calculte pressure drop this properity is change with temperature my problem about using matris. error message says your variable is not scalar because If I use G^2. on the other hand I multiplicate with itself G.G is give result very big I understand it multiplicate element by element
Re: MathCAD
07/21/2008 10:10 AM
What a strange equation!
Viscosity appears in the numerator while calculating Reynolds' Number. Most pressure drop in pipes calculations involve the raising of Reynolds' Number to some non-unity power.
Re: MathCAD
07/21/2008 11:05 AM
I don't get you.
"It is only when we die that we become Immortal."
Engineering Fields - Mechanical Engineering - Member Engineering Fields - Piping Design Engineering - Member United Kingdom - Member - New Member Technical Fields - Education - New Member Popular Science - Cosmology - New Member
Re: MathCAD
07/22/2008 4:41 AM
I use Mathcad on a daily basis at work so may be able to help you out here.
I need to see a picture of what is wrong though to aid the understanding. There are others out there on this forum who could help too I believe and a picture would be beneficial to all.
Kev Brown
Re: MathCAD
07/22/2008 4:55 AM
Thanks very much about your interest to my problem I solve it today. I find my mistake so I calculate and attain my aim.
If I have problem you will the firsrt person to consult in my mind
have nice day
Register to Reply 4 comments
alperr125 (1); High Lander (1); Kev_brown (1); PWSlack (1)
